I need to generate 50usec RF (100MHz) pulses with 500us repetition period. The waveform needs to be syncronized with an external trigger.
I tried Trig In but it doesn´t work (ot doesn´t trigger N5183A).
How can I trigger it?
I'm not to familiar with the N5183A MXG. I asked around and this was the response I received.
"The only other way that I can think of (with the analog unit) is to use the Pulse Source in the “Gated” mode. Here for example, you could start the pulse with a rising edge trigger signal but the trigger level would need to stay high in order to enable the pulse to continue to play."
Hope this helps.
Pete
Hope this helps.
Pete
