I am using E5061B network analyser.
1. I am getting S11 data from analyser
2. How to calculate the resistance and capacitance from s11 data?
3. In s11 data..we have 3 columns with data
4.First Column : frequency
5. second Column : Magnitude
6. third Column : Phase angle
7. How to calculate the resistance and capacitance from above values.
Kindly help
Thank you.
This would be my approach.
I assume you are reading a Touchstone file, given you mention the 3 columns.
Let S11_dB be the magnitude in dB (2nd column)
Dave
