I have remote programmed the DSOX1102G scope to setup the time-base and 2 channels. This was successful.
I am using a C library on our bespoke PC/operating system.
I cannot get the waveform to capture correctly via the read USB connection to my PC. I only need to capture about 1000 points not the full detail but. Can I use SAVE:WAVeform commands to do this as a CSV and if so how? (Using setup and WAVeform:DATA only captures the first 1000 points.)
NOTE - I am ising this scope and a replacement for an old TEK scope and all my post processing algorithms need to remain the same for backwards compatibility. I am only looking for the peak values of my waveform and their relationship, I do not need the precision that a point by point waveform capture from its entire memory will give.
Best Regards
Adrian
I'm sorry, but I can't figure out what you want. As near as I can make out, you want to capture and save 1000 points, and the scope is capturing 1000 points.
What does "but not the full detail" mean? What do you want to capture?
Are you having problems saving? Do you want to save to a separate USB memory stick, or are you trying to offload the data through the USB to your controlling PC
Al
