Attempting to make multiple data acquisitions to a USB with the 34465A. What I am trying to do is make 38 different data acquisitions from the Keysight 34465A and export this onto a USB drive. However, I am currently running into a problem where each file is being saved as Data, so unless I go in and manually change each file name before starting the next capture, it will just overwrite the previous capture. So is there a way to automatically make the file name different each time (i.e. Data1, Data2, Data3, etc.)?
When saving readings a specific file name must be entered each time. The DMM firmware cannot automatically update/change a file name for successive acquisitions. The only time file names are updated automatically is during data logging and the maximum number of readings exceeds the selected Row/File size set from the front panel. Page 85 of the operating and service guide address this.
