When self test is run on my E8257D and when it is 86% complete unit kicks out of the testing and says "system error; a missing or damaged system file was encountered while trying to diagnose the system". Has anyone had this problem and /or know how to fix this?
Thank you for any help.
I'm not the expert on the E8257D so I asked around. It was suggested to re-install the firmware and see if that fixed the problem. If that doesn't fix the problem the CPU board may need to be replaced.
E8257D, E8257N, E8267D, E8663D PSG Signal Generator Firmware | Keysight (formerly Agilent’s Electronic Measurement)
Hope this helps
Thysell
