This note introduces a quick flow of Digital Pre-Distortion (dpd ) with a user-friendly UI.
Memory effects can be considered by applying appropriate algorithms.
SystemVue provides three approaches to exact model: Volterra Series, Memory Polnomial and Look-Up-Table (lut).
Of course, you can also use your own algorithms by simply copying the code into this DPD UI.
Signal preconditioning is also available by Crest Factor Reduction (cfr ).
