I'm getting "Vertical Test Group" Failed on my Agilent MSO8104A. Looking at the logs shows that all values/voltages are nominal but the test is still flagged as FAILED. Any thoughts on this?
Log:
** Test Run ** Scope Tests --- 27 APR 2017 13:12:01
Reference setting for gain ratio
Preamp Settings Chan 1 , CPL=DC, IMP=HiZ, BWL=OFF
****INPUT=G1, Mux=X1, GainSet1=X1.6, GainSet2=X2.6, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.614407&E, Expected Ratio(+/-20%)=2.600000
****INPUT=G1, Mux=X1, GainSet1=X1.6, GainSet2=X1, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.009772&E, Expected Ratio(+/-20%)=2.000000
****INPUT=G1, Mux=X1, GainSet1=X1.6, GainSet2=X2.6, Vernier=255
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.615183&E, Expected Ratio(+/-20%)=1.600000
****INPUT=G1, Mux=X1, GainSet1=X1, GainSet2=X2.6, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.029605&E, Expected Ratio(+/-20%)=2.000000
****INPUT=G1, Mux=X2, GainSet1=X1.6, GainSet2=X2.6, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B0.040111&E, Expected Ratio(+/-20%)=0.040300
****INPUT=G2, Mux=X1, GainSet1=X1.6, GainSet2=X2.6, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.607465&E, Expected Ratio(+/-20%)=2.600000
****INPUT=G2, Mux=X1, GainSet1=X1.6, GainSet2=X1, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.613885&E, Expected Ratio(+/-20%)=1.600000
****INPUT=G2, Mux=X1, GainSet1=X1, GainSet2=X2.6, Vernier=0
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.026905&E, Expected Ratio(+/-20%)=2.000000
****INPUT=G2, Mux=X2, GainSet1=X1.6, GainSet2=X2.6, Vernier=0
Preamp Settings Chan 2 , CPL=DC, IMP=HiZ, BWL=OFF
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.599576&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.011475&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.608126&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.028099&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B0.039720&E, Expected Ratio(+/-20%)=0.040300
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.601717&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.607186&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.024429&E, Expected Ratio(+/-20%)=2.000000
Preamp Settings Chan 3 , CPL=DC, IMP=HiZ, BWL=OFF
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.610994&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.024590&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.612272&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.031250&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B0.040159&E, Expected Ratio(+/-20%)=0.040300
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.607963&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.616540&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.026127&E, Expected Ratio(+/-20%)=2.000000
Preamp Settings Chan 4 , CPL=DC, IMP=HiZ, BWL=OFF
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.624190&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.025000&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.615691&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.038591&E, Expected Ratio(+/-20%)=2.000000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B0.039324&E, Expected Ratio(+/-20%)=0.040300
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.603189&E, Expected Ratio(+/-20%)=2.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B1.611123&E, Expected Ratio(+/-20%)=1.600000
Status: &C0&&B -- PASSED&E, Gain Ratio=&C4&&B2.019343&E, Expected Ratio(+/-20%)=2.000000
Chan 1 Relay actuations:
***Imp Sel = 0 ***25x Atten = 0 ***10x Atten = 0
Chan 2 Relay actuations:
Chan 3 Relay actuations:
Chan 4 Relay actuations:
Desired Preamp Differential Output Voltage = 0.200V
Offset Dac = 0x0 Offset Range = 1 (+Chan 1 ) = 0.403V (-Chan 1 ) = 0.604V
Desired Preamp Differential Output Voltage = -0.200V
Offset Dac = 0x0 Offset Range = 1 (+Chan 1 ) = 0.604V (-Chan 1 ) = 0.404V
Offset Dac = 0x0 Offset Range = 1 (+Chan 2 ) = 0.402V (-Chan 2 ) = 0.602V
Offset Dac = 0x0 Offset Range = 1 (+Chan 2 ) = 0.603V (-Chan 2 ) = 0.403V
Offset Dac = 0x0 Offset Range = 1 (+Chan 3 ) = 0.403V (-Chan 3 ) = 0.603V
Offset Dac = 0x0 Offset Range = 1 (+Chan 3 ) = 0.604V (-Chan 3 ) = 0.404V
Offset Dac = 0x0 Offset Range = 1 (+Chan 4 ) = 0.403V (-Chan 4 ) = 0.603V
Offset Dac = 0x0 Offset Range = 1 (+Chan 4 ) = 0.604V (-Chan 4 ) = 0.404V
Test: &B&UVertical Test Group&E&C13&&B -- FAILED&E
Test: &B&UTrigger Test Group&E&B -- PASSED&E
Chan 1 Slice Data = 88,94,90,97,91,89,87,89,89,88,96,88,91,94,92,96,
Chan 2 Slice Data = 67,68,65,67,65,64,65,69,63,63,73,70,69,71,65,62,
Slices in error = 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,
Chan 3 Slice Data = 63,68,60,62,70,63,65,69,62,57,60,62,64,67,62,66,
Chan 4 Slice Data = 64,72,66,64,63,71,70,64,64,66,69,66,61,63,63,66,
Test: &B&UAdc Test Group&E&B -- PASSED&E
Long Count = 105
Long Count Residue = 148
Short Count = 60
Short Count Residue = 149
Test: &B&UTimebase Test Group&E&B -- PASSED&E
Test: &B&UAcq Interface Test Group&E&B -- PASSED&E
Test: &B&UAcq Memory Group&E&B -- PASSED&E
System Temp 36.7 Degrees C
Test: &B&UMisc Scope Test Group&E&B -- PASSED&E
&BFinal Result: &E&B&UScope Tests&E&C13&&B -- FAILED&E
There is some sort of internal failure. You should think about getting it repaired or replaced. Note that this scope was discontinued in September 2011. The official 'end of support' was 5 1/2 years later in March 2017. It might be repairable on a 'best effort' basis. You might try calling your local Technical Call Center, to see if it repairable, or maybe just needs a factory cal.
Al
