You can adjust what is visible to other users by taking the following steps:
- Go to your avatar photo in the upper right
- Select "Edit Profile"
- Go to the "Privacy" tab
- Set your "Name" as Visible To "Everyone"
If you want to display your name rather than your user handle for a given post, you can't do that. The Community is set up to display posts by user handle. But other users can navigate to your profile and see the information you choose to share there.
Hi Fred -
Hope that helps.
Jill
