Will the 83752B Synthesized Sweeper work as a source for 8510C? The 8510C Pre-Flight setup document only lists up to 8360 series and not the 8370 and hence not sure if its readily compatible with 8510C or weather there are significant hoops I need to jump over to get them to work. Any insight you have would help.
Sujith
Anybody have an answer on this? I have a 83752B for sale locally and really would like to know in advance if it will work with 8510C. Thanks.
