VTB analysis error with MCS=0 option
Question asked by AMPARO on Feb 15, 2017
Latest reply on Feb 16, 2017 by AMPARO
I am using the VTB component Tx_1Ant_Analysys an ADS 2016.01 and the MCS=0 1 and 2 shows an error :
error detected by HPEESOFSIM during circuit set up "VTB1_Env"
VTB exception occurred
Failed getting por datatype
With this log file:
Wifi_test_VTB_20MHz_MCS_0_VTB.log
SystemVue (TM) Ver: 2015.01.1.8 Date: Jul 23 2015, 11:56:59
Initializing analysis "Tx_1Ant_Analysis" from workspace "WLAN_802.11ac_Tx"...
Analysis "Tx_1Ant_Analysis" initialization complete.
Running analysis "Tx_1Ant_Analysis" from workspace "WLAN_802.11ac_Tx"...
Error: 'Tx_1Ant': SystemVue License not available.
Analysis "Tx_1Ant_Analysis" failed.
If  I use MCS=3 there is not error and the log file is
WLAN_11ac_Src_RangeCheck 'Tx_1Ant__SVSource.RangeCheck':
System Configurations:
1. Number of transmit antenna ports is 1.
2. Sample Rate is 4e+007. Total sample points per one frame is: 15360. Idle sample points is: 480; Preamble sample points is: 1600; VHT Data sample points is: 13280.
3. Preamble OFDM symbol is: 10; VHT Data OFDM symbol is: 83.
4. Space Time Block Coding is Off; Numbler of total space-time streams is: 1; Numbler of VHT-LTFs is: 1.
Users Configurations:
Number of active users is: 1;
1. For User 0: number of Space-time Streams N_sts is 1; MCS is 3; CodingType is BCC; AMPDU Length is 1068 bytes; PSDU_LENGTH is 1076 bytes;
WLAN_11ac_EVM 'Tx_1Ant.W1':
WLAN_11ac_EVM 'Tx_1Ant.W1': Frame 1:
RCE (EVM) = -16.935 dB,
14.231 %rms,
RCE_Peak = -6.8405 dB,
45.496 %rms,
DataRCE = -16.803 dB,
14.45 %rms,
PilotRCE = -19.174 dB,
10.998 %rms,
IQGainImb = -0.099712 dB,
IQ_Offset = -42.83 dB,
IQ_QuadErr = -0.024173 Degree,
SyncCorr = 0.99166 ,
FreqErr = -0.74984 Hz,
SymClkErr = -1.611 ppm,
GI 0.250, 1 streams, 16 QAM, 83 data symbols used for EVM.
WLAN_11ac_EVM 'Tx_1Ant.W1': EVM analysis is done. 1 frames succesfully analyzed.
Analysis "Tx_1Ant_Analysis" complete.
Why I cant use MCS=0 or 1 or 2, BPSK or QPSK options?
Thanks in advance
Amparo
