Hello, dear developers Keysight. Can you answer the question EMPro program, my question is this - in the near field can be measured by the distance between the transmitting and receiving antennas in the form of points and learn that emits every point? If possible it is better examples, I will be grateful for your response!
EMPro FDTD simulation has all kinds of field sensors, including Point Sensor, You can insert Points sensors between antennas to record near field data.
