How do I time my modes to correspond to kinematics?
Kinematics can be aligned with mode switches by clicking the ‘View’ tab and open the ‘Time Domain Analysis’ window.
Click the “Settings” tab and select “max time span: Kinematics.” This will run the simulation to the final waypoint of all platforms in the scenario regardless of whether or not they create any RF.
Click on the ‘Timer’ tab and play back the simulation. Pause the simulation and note the time when you want to play the mode:
Use the time – 9.4 seconds in this case – and click on the emitter level. Change the start time of the mode in the ‘start time’ text box.
