How many UXGs do I need to create N pulses at the same time (pulse-on-pulse)? How do I configure multi-channel, multi-port systems for pulse-on-pulse with angle-of-arrival?
Each N5193A UXG is capable of generating one pulse at a time.
To generate N pulse at the same time you would need N N5193A UXGs
For angle of arrive (AOA) the number of UXGs needed is N times the number of SUT ports.
For example, if you want 3 pulses at the same time and are doing two port AOA you would need 6 (3*2) UXGs.
