Hi
I am using N6705 part.
I wanted to know the mating banana connector part number to be used at the output of the power supply and the trigger in and trigger out BNC mating part number.
Regards
nitesh
Hi
Regards
nitesh
Hi nitesh006,
The banana connector is a common part which can be easily purchased at any electronic parts store. For your information, Keysight do have the E3600A-100 Test Lead Kit (Termination: banana to hook clips, with maximum current of 5 Amperes continuous). You may check your wire size and length in the Keysight N6705 DC Power Analyzer User's Guide on Page 33 and 34.
The link to the user's guide is provided as follows:
As for the trigger in and trigger out BNC cable, the part number is U2921A-100.
Hi nitesh006,
