Is there a way to upgrade the older style E4440A spectrum analyzers from the Floppy to a USB? I'd like to save/load files from a USB stick instead of a floppy disk!
There was a question similar to this from 2012 which discusses the usage of a floppy drive emulator. Here is the link to that forum discussion: https://community.keysight.com/thread/19320
Another method you can use is adding a toolbar add-in for Excel and Word. This allows you to capture data and place it in an excel worksheet, but not limited to other capabilities like screen captures, starting repeated measurements, and several others. Here is the link to the document that can guide you through the set up and show you how to get information from the PSA: http://www.keysight.com/upload/cmc_upload/All/EPSG072856.pdf
