I was "tuning" a design and ADS froze during the session (ADS2014C linux). Now the library I was working with can not be saved because it is stuck in "read only" mode. From the ADS main window, I went into Manage Libraries menu pick then selected the locked library and then clicked on the pulldown "Change Library Mode" to "Shared" but when ever I try to save a change I get library is "read-only" message even though ADS thinks it is "Shared". Are there any lock files that need to be deleted, linux file permission changes, or other tricks to get the library back to "Shared" mode?
I got it to change back like this. In your project, go to where the schematic file is located. This can be done by going to the schematic location and deleting the "sch.oa.cdslck" file and then reopening the schematic. Here's some screenshots to show you what I mean:
