Hi there,
It am trying to import a BSIM4SOI Spectre model into ADS 2016 using File->Import->Netlist File option but it does not work. Basically, it only imports the constant such as Pi and so on. It does not include any other model parameters.
Could you please provide a robust solution to this matter ASAP?
Mohammadreza
ADS supports import of Spectre models, so this procedure should work. Please contact your local Technical Support department for assistance.
