I have a problem with driver_ivi_matlab_AgInfiniiVision-x64_2.1.9.0 on the windows 10. The installation displays problem , that my system has not been modified. Can you help me with installation? Is it possible to instal the driver sucessfully or this driver will be compatible with windows 10?
Thank you for the advance.
This might not be an issue with Win10. Just try to re-install again, I believe it should work (I've encountered it before).
