JAbrams
Well I am in similar situation. I need to measure Residual Phase Noise.
I did some serching and find some materials like the one show below.
http://www.keysight.com/upload/cmc_upload/All/PhaseNoise_webcast19Jul12.pdf
In your case probably the direct Phase Noise measurement method can be perform with Spectrum Analyzer.
Your are using E4407B ESA-E, check it you do not have Noise Figure option on the Spectrum Analyzer (SA), that will simplify your problem.
In my case direct Phase Noise measurement do not work and I need to use Phase Detector technique.
I have a lot of problem with that.
JAbrams
