How to manage test Results of ICB Board from an In-Circuit Tester
Question asked by haizen on Nov 15, 2016
Latest reply on Feb 2, 2017 by dbailey
I need to extract data from a log file and sort the data in an Excel file. Details are as follows:
  • Log File is a measurement result produced by an In-Circuit Tester (no info. about it, no name, no type, nothing).
  • Measurement Result is for an ICB Board (not sure what measurement it is e.g voltage, current, resistance)
  • Log File is taken directly from ICT equipment but data is not in Excel format
  • I checked the property of the log file and it says the Type of file: File
Information I found out:
  • I use CheckFileType.com and it says that the log file is an ASCII Text
  • The figure bold is the component name such as resistor diode etc. {@BLOCK|f1|00{@A-FUS|0|....
QUESTION:
My company requested these measurements from our ICB supplier. Now the problem is that we don't know how to manage it.
  • Is there any recommended software/method on how to manage these datas? As in to present it nicely
  • What do these @RPT , @BLOCK , @FUS means?
SAMPLE DATA (not everything from the file, ):
*Beginning of data*
{@BATCH|E41500AA||2233|1||btest|151212173326||THALES-4|ICB-41500-003|RevA||| {@BTEST|MYSK50153695|00|151212174028|000045|0|all||n|n|151212174113||1 {@PF|pins|0|0}
{@BLOCK|f1|00{@A-FUS|0|+4.314677E+00{@LIM2|+1.700000E+01|+0.000000E+00}}}
{@BLOCK|f2|00{@A-FUS|0|+4.109951E+00{@LIM2|+1.600000E+01|+0.000000E+00}}}
{@BLOCK|f3|00{@A-FUS|0|+3.751765E+00{@LIM2|+1.600000E+01|+0.000000E+00}}}
{@BLOCK|f4|00{@A-FUS|0|+4.155438E+00{@LIM2|+1.600000E+01|+0.000000E+00}}}
*Middle of data*
{@RPT----------------------------------------}
{@RPTICB-E41500-003}
{@RPTSat Dec 12 17:40:33 2015}
{@RPTcr63-cr64_polarity HAS FAILED}
{@RPTMeasured:   1.4223}
{@RPTHigh Limit: 620.00m}
{@RPTLow Limit:  427.00m}
{@RPTForward VOLTAGE drop}
{@RPTStatus:  2cH}
{@RPTMoa Voltage/Current Compliance}
{@RPTDetector Over Range}
{@RPTIntegrator Over Voltage}
{@BLOCKcr63-cr64_polarity1
{@A-DIO7+1.422303E+00{@LIM26.20E-01+4.270000E-01}}
{@RPTDEVICES IN PARALLEL}
{@RPTcr63%cr & cr64%cr}
{@RPTcr65-cr66_polarity HAS FAILED}
{@RPTHigh Limit: 657.00m}
{@RPTLow Limit:  500.00m}
{@RPTStatus:  2cH}
