I am trying to change the way my ports are numbered in my project tree; for instance, I have a balun with a WG port input and 2 component port outputs. I would like my WG port to be port 1, but it is currently port 3. I can swap the two component ports around, but I can't move the WG port (and I can't move the component ports to be after the WG port either). Is there another way to do this? It seems like something that should be easy to do, but I can't figure it out
Indeed the relative order between WG ports and component ports cannot be changed in EMPro. I would suggest that you contact technical support to submit an enhancement request on this.
