I am trying to output a log header in xml format, my output should look like this <Test Number ="34" value="555" />
So i have been playing with print using .....
Now in my bt basic environment I have defined bellow
F$ = """<Test Number="" ,"""& val$(34) & ""","" value="","""&val$(555)&""",/"
print using F$ -> prints out: <Test Number=34 value=555
But I want to have some xml format, there fore between the values, I need character ", my desired output should look this Test Number ="34" value="555"
My question is, how to add the " inside my ouput? I have tryied even with chr$(34) but I get syntax erros, in the documentation I have not found similar syntax for image
Try adding it this way + CHR$(34)
