I am trying to design a simple CPW line:
___________________
| ground | Line | ground |
SUBSTRATE
For defining the ports I am using <new feed definition> and I am connecting this port with the negative side on the ground and the positive side on Line.
is it the correct way to do that?
thanks in advance
Waveguide port is the best port model for CPW designs. Voltage source is not the best option for your design.
