Is there any way to trigger out a signal if limit is passed?
Question asked by rodrigo.romo@interlatin.com.mx on Oct 12, 2016
Latest reply on Oct 14, 2016 by Dr_joel
I need to automate a process when measuring antennas, basically I need to set up a limit for SWR and send a trigger signal out if the limit is passed. The typical response would be, you need to communicate with the instrument via SCPI commands and use a I\0 card for the trigger signal, but I need to know if any bench NA is able to do so.
#limit test
#trigger out
