Momentum Optimization issue
Question asked by Riju on Oct 4, 2016
Latest reply on Oct 6, 2016 by bafisher
I parameterized components in schemtaic then I generate/update layout from the schematic. In the layout, I renamed the variable name and run EM simulation and the generated EM Model is imported in the schematic with other component/circuitry for cosimulation and optimization.
cosimulation optimization settings
I want to optimize the stub lengths (ss1/2wel and tl1/2wel variables) in the cosimulation, but I am facing few problems...
1. I set Random optimization and each pass is taking huge time (45 to 50 minutes)
2. After 2 to 3 pass, it terminates with the following error message.
optimization error
3. After getting the optimized values (although not fully optimized, I updated the design after it unexpectedly terminated with the error message shown above), I get one result. But if I apply those changes of parameters in the layout and again do EM simulation and replace the old model by this newly updated EM model I get different result although the parameter values are same.
Another problem I am facing is - in layout drawing, when I generate the layout from schematic having transmission lines, I cant point the marker exactly at the edge point of transmission lines in spite of setting denser grid. If I zoom in I can see the point/marker doesnt coincide with the edges of microstrip line,
