Hi.
I'm using oscilloscope MSO X 2012A!
so, I want to save waveform ... to PC!!! but, I don't know how to save!
I don't know error 257 and Temp!!! what it means??????
I can't find examples. Help me...Please.
This is sequence. what is problem???
*IDN?
:TRIGger:EDGE:SOURce CHANNEL1
:TRIGger:EDGE:COUPling DC
:TRIGger:GLITch:LESSthan 20 US
:TRIGger:FORCe
:TRIGger:MODE EDGE
:TRIGger:GLITch:LESSthan 79 US
:TRIGger:PATTern:FORMat?
:CHANnel1:RANGe 8 V
:TRIGger:SWEep NORMal
:STATus? CHANNEL1
:TIMebase:SCALe 20 US
:MEASure:ALL
:SAVE?
:SAVE:WMEMory:SOURce?
:SAVE:PWD? <-\Temp\
:SAVE:FILename "osc"
:SAVE:WAVeform:FORMat CSV
:SAVE:WAVeform:SEGMented?
:SAVE:WAVeform:LENGth:MAX?
:SYSTem:ERRor?
:WAVeform:BYTeorder LSBFirst
:WAVeform:FORMat WORD
:WAVeform:UNSigned 0
:WAVeform:POINts:MODE NORMal
:WAVeform:SEGMented:COUNt?
:ACQuire:MODE RTIMe
:ACQuire:COUNt?
:WAVeform:SOURce CHANNEL1
:SINGle
*SAV 1 <-save to setup_1
:SAVE:WAVeform:STARt "C:\Temp\osc.csv" <- error 257, filename error
(Wait 10ms)
:RUN
Hi eunji,
Have you tried to do the same process but save to an external source (USB flash drive), instead of directly to the PC?
Best,
Josh
