Momentum: Generate farfield from command line
Question asked by rain_physics on Sep 19, 2016
Latest reply on Oct 18, 2016 by bafisher
I am following the help of ADS-2016.01 Running a momentum from command line
I have generated S-Parameter successfully using the following command as given in the help
adsMomWrapper -O -3D proj proj
In order to generate the farfield, I used the following command as given in the help
adsMomWrapper -FF proj proj
When I execute the above command, I get the following error.
--ERROR-----------------------------------------------
File for view plan proj could not be opened
check   : - existence
               - access permission
Can anyone suggest me which step I am missing?
