I've been struggling to find detailed documentation on how to change the compiler environment for User-compiled Models (UCMs) within ADS...
I've constructed a non-linear UCM for use in the ADS circuit simulator; the model requires that I calculate the matrix inverse of a large Z-parameter matrix in order represent it in the Y-parameter format required by the UCM. However, my own matrix inverse code is not efficient enough to perform these calculations for larger networks, thus I would like to use BLAS/LAPACK C++ libraries to simplify aid in these calculations.
There isn't a lot of detail in the UCM documentation so I've not been able to find a way to link additional C++ libraries during the compilation process. Any help or suggestions would be greatly appreciated.
Many thanks,
Sean
