Hi ,i am very new to ADS i am getting an error msg "Qi is an instance of unidentified model cb_hp_AT60200_19900409"
pls help me.
pls help me.
ADS returns that error if it cannot find the model for the transistor. This specific model is part of the "Microwave Transistors" library which can be found zipped somewhere in your ADS installation folder (C:\Agilent\ADS2014_01\oalibs\ComponentLib in my case).
You have to unpack that library first and then add it to the libraries of your workspace. Then the model will be found when you run a simulation
