Hi Admin,
(1) We used VISA command to check probe info of each channel but the result were abnormal, can you kindly check it?
Our test environment as below:
Scope: MSO9404A Infiniium
Software Revision: 05.60.00501
Channel 1: 1132A
Channel 2: 1132A
Channel 3: 1132A
Channel 4: 1132A
Calibration Date: 30 JUN 2016
(2)CMD as below
:CALibrate:DATE?
Response from scope: DEC 2014 17:02:17,13 DEC 2014 17:02:17 (correct should be 30 JUN 2016)
:CALibrate:STATus?
Response from scope: 1,1,1,1,1,1,1,1,1,1
:CALibrate:DATE? CHANnel<N>
Response from scope: Query UNTERMINATED
thank you!
