S-parameter port  is electrically large
Question asked by FoxMax on Jun 21, 2016
Latest reply on Jul 18, 2016 by MARNIKB
Good afternoon. Please help us to deal with ports. At Rogers RO4350B (Dielectric constant = 3,66, Loss Tang = 0.0037, Metal Thickness = 0.018 mm, Substrate Height 0.508 mm, Resistyvity = 1) do microstrip filter - Hairpin 9.5 GHz. In the simulation, the logs Momentum appears
--- WARNING ---
The size of the plus pin for S-parameter port 1 is electrically large
above 15.4097 GHz, S-parameters may become unphysical.
Models from 5 to 17 GHz. I tried in port settings to specify its height, approximately equal to lambda / 20 = 18 mm / 20 = 0.9 mm. Port type is normal, that is, those who are set automatically when you create the topology.
