I would like to know the difference between 82357A and -B.
The reason is that I will try to use the maintenance software for E44xx -B signal generators, and the prerequisites states that this software requires the -A version...
Hi Uky,
I'd imagine the B version is simply a later version, maybe with some subtle hardware or firmware changes. I had a quick look at the manuals for the instruments but I couldn't find any reference to the card version. I would just try it with the B version - either it will run as expected or ( and I think this is very unlikley ) you'll get some inexplicable bug at some point: if the latter, at least you know that it could be an interface card version issue.
HTH,
Mike Watts
