I have issue with signal generator, it stuck at MB Flash while booting and firmware cannot be updated via lan or rs232.
I have tried using to update the firmware but it is stuck. Only good thing is that signal generator ping over the LAN cable.
Please tell what to do regarding it?
Your worthy comments are welcomed
The only thing I can suggest would be to re-seat the CPU board. If that doesn't work then you probably have a bad assembly. I've seen issues where part of the circuit involved in firmware upgrades is bad, but doesn't show any symptoms until you try to load new firmware. This could be one of those cases.
