I have a setup for measuring the EVM for 3GPP WCDMA data, as shown below
The question is I want to replace the test signal from a signal obtained in virtuoso (let's say I have the .csv file for the signal). Could you please tell me how to import that and make it work on ADS?
Thanks!
In Dataflow simulations, you have a Block called ReadFile that can read data from a text file (see figure in attachment). You can use that if the data is uniformly sampled.
