Hi.
I need to optimize a layout using ADS 2015.01. So, I created an emModel and put it into a Schematic. I defined an Optimization and ran it. However, the Optimization Cockpit has not updated in real time as it does when a Schematic (without emModel) is optimized. Is it normal when an emModel is part of the circuit to be optimized?
Daniel
According to me (and my memories regarding these kinds of simulations) it should update in real-time in your
optimization window.
I however can't help you further if you do not supply any more information. (Pictures of your sim settings, schematic, your emModel, the relavant layout,......)
