Command Expert and a HP3478A
Question asked by Harke001 on Jan 20, 2016
Latest reply on Jan 21, 2016 by Harke001
I just installed Command Expert and related software. I use a F82357 that otherwise seems to work well. As a test I try to connect a HP3478A multimeter. I get "connection succeeded" after selecting the default SCPI 99 and editing the correct adress (13). Pressing "update" gives: path error: c:\program data\keysight\Command Expert\instruments.xml denied. Then I can only start again to get the same result. Connection Expert does not seem to run? I cannot find the program data folder either....
Any advise please?
Thanks in advance,
Harke
