I am using SCPI to measure an (unknown) RF power level with a U2002A sensor. I cannot figure out how to make measurements below -32 dBm.
I use tho following power sensor initialization:
-> SYST:PRES
-> SENS:FREQ 1GHZ
-> SENS:AVER:COUNT:AUTO ON
And then i query the power with the MEAS? command.
Below -32 dBm, the measurement fails due to a time-out.
Using the Power Panel, the sensor reports RF power even without a source connected, down to the noise floor.
How should I initialize and query the power sensor to avoid measurement time-out when measuring an unknown RF power level?
-> SYST:PRES
-> SENS:FREQ 1GHZ
Maybe the config command makes the measure range above -32dB, will it work if you use the "read?" command?
