Dear all,
Does any of you have experience with galil motor control? I am using the galil .NET library within VEE as part of an antenna measurement software and the memory usage in task manager keeps increasing until the program stops responding after a couple of hours. I don’t have this problem using visual C# with the same .NET. Could it be caused by some dodgy memory management between VEE and .NET? I have no idea how it’s done. I’d rather not have to re-write the whole automation software in C#. I’d appreciate any pointers towards a solution.
Kind regards,
Pascal Aubry
p.s. using VEE Pro 9.3 under Windows 7
Kind regards,
Pascal Aubry
I'm not familiar with the .NET control you are using but if there is good documentation it would be worth reviewing that, especially in respect of object handling - for example there might be .NET objects you create as part of the process but do not dispose of them properly and VEE tends to hold on to references ( which in turn will keep the objects in memory ).
HTH
Edited by: Mike on Mar 12, 2015 8:12 AM
