I am using ICCAP for modeling the HEMT device using Angelov GaN model toolkit. I am finding some errors while extraction of parameters. I have followed the steps for Extraction/tuning of parameters given in document on "Angelov GaN model tool kit" (Available on Keysight website). I am facing following Warnings/Errors while executing extraction steps in Demo mode:
WARNING: Error(s) during Expression Evaluation or resulting operations:
ERROR: hpeesofsim simulation failed
hpeesofsim terminated due to an error.
Simulation debugger window:
=================================================================================================hpeesofsim (*) 410.shp Mar 17 2014 (64-bit built: 03/17/14 17:33:40)
Copyright Agilent Technologies, 1989-2014.
Processing VAMS source 'C:/Agilent/ICCAP_2014_04/examples/demo_features/6_SIMULATORS/2_ADS/5_NETLIST_TEMPLATES/5_III_V_Devices/Angelov_GaN/angelov_gan.va'
>vamscomp -amswork c:\users\sumit\appdata\local\temp\.ic6.ams_work -S C:/Agilent/ICCAP_2014_04/examples/demo_features/6_SIMULATORS/2_ADS/5_NETLIST_TEMPLATES/5_III_V_Devices/Angelov_GaN/angelov_gan.va
'vamscomp' failed with exit with status 1.
Error detected by hpeesofsim during netlist parsing.
#load "veriloga" command failed
Kindly suggest me the way to fix it.
Thank you.
Please contact EEsof Technical Support with this issue, and someone will assist with this problem.
You can send email to eesof_support@keysight.com, or call 1 800 473 3763.
A few quick comments:
1) check that you have ADS_DIR in PC environment variables defined to point to your ADS installation
directory.. e.g. something like: C:\agilent\ADS2014_01
2) normally one would point to the angelov_gan.va file in the current ADS veriloga directory, e.g.
#load "veriloga", "C:\agilent\ADS2014_01\veriloga\angelov_gan.va"
Please follow up with our Technical Support department for further information.
Best regards
Else
