Hi
I am currently trying to communicate with a third party instrument via direct I/O in Vee.
It is connected to the PC with a rs485 to USB cable and comes with two commands;
GET:POS X
SET:POS X_N
Bus Parameters are:
- 9600 baud
- 8 bit
- 1 stop bit
- no parity
All send commands have to be terminated by CR
The above settings are set in the advanced instruments properties tab, (See attached pictures). I am unsure on the handshaking requirements, the manual does not mention it but in a COMtest program provided by the manufacturer the none option selected in there test GUI.
I tried sending the instrument write text commands (see attached pictures) but nothing seems to happen.
I have tried sending it in STR and QSTR formats etc
Is there something I am doing wrong or any suggestions on what I can try next
Any help would be much appreciated
Edited by: SIGGENMAD on Feb 25, 2016 5:43 PM
GET:POS X
SET:POS X_N
Bus Parameters are:
- 9600 baud
- 8 bit
- 1 stop bit
- no parity
The other thing I'd say is that 'CR' most likely refers the the carriage return character, so in the Advanced Instrument Properties -> Direct I/O screenshot you posted, EOL sequence should be "\r"
Mike Watts
