Not sure if this is the right spot for Command Expert topics, though I'm installing the bundled Benchvue/Command Expert/IVI software.
In this case, Command Expert v1_4_944 including the "Excel" option is installed onto Win 7/64 with Office 2010.
The scenario is having a Word document with an embedded Excel table. When attempting to edit the Excel table the error as in the attached picture is received.
Removing Command Expert, restores the correct function of being able to edit embedded excel tables.
Cheers
Andrew
Cheers
Andrew
Brian
