Should the probes be disconnected from the pod cables when running this test? The 16800 Service Guide makes no mention about disconnecting anything, but the test fails when the machine is connected to a target, and passes once disconnected.
I ran the test repetitively while disconnecting probes, and it continuously fails until the last probe is disconnected.
Al
