Hi there,
I need some help, I am running a test which requires that the power supply should be running during the period of the test, the problem is that power supply (Agilent n6950A), is going to standby mode after some time of running e.g 1 hour. how can i fix this problem, i tried to look on the datasheet but i could not find somthing.
Edited by: Mo on Jun 24, 2015 2:37 AM
On your Titan press the [Menu] soft key. Then select System > Preferences > Display > Saver. Here you should see "Saver Delay." Enter the number of minutes that you would like to delay standby mode. The delay can be set from 30 to 999 minutes in 1 minute increments.
Or
From the same screen, you can simply uncheck the screen saver box.
