I was looking for a suggestion 'box' for the --Agilent-- Keysight oscilloscopes but couldn't find one so I'll post here.
I find that quite often when changing trigger options on the *Trigger Menu* it is convenient to temporarily swap the trigger *Mode* between *auto/normal*.
This allows the waveform to be seen and makes adjustment easier. This assumes, of course, that I usually have the DSO in *Normal* mode otherwise it's moot.
To do this involves changing to a different menu and then returning to the *Trigger* menu to make the adjustment.
The trigger menu has only three options - It would be possible to duplicate a few of the Mode menu options on the Trigger menu. I would suggest *Mode* and *Coupling*.
Anyway that's the suggestion.
I would appreciate comments on whether it's a good idea and how to "officially" suggest it.
bye
bye
- Press [Utility] > Quick Action > Action
- Select "Quick Trigger Mode"
- From then on, the [Quick Action] hardkey on the Front Panel can be used to quickly toggle the Trigger Mode from any menu.
