Hi
I wrote a function in visual studio 2010 in c++, which calculates the average current consumption from defined number os samples with defined sample interval. Problem is that i sporadically get -420 query unterminated error and communication hangs. Need to reconnect usb cable to resume communication. Problem especially occurs after first switch on of device. I thought it can be a timing error, so I add some *WAI and *OPC? commands but with no effect. I add my functions below (and attach cpp file). Any help would be greatly appreciated.
float MeasureAverageCurrentDC_mA(int sample_number, float sample_interval)
float result;
if(sample_interval < 0.05)
sample_interval = 0.05;
else if(sample_interval > 600)
sample_interval = 600;
if(sample_number < 1)
sample_number = 1;
else if(sample_number > 50000)
sample_number = 50000;
char samp_num[10];
char samp_int[10];
char table[90];
char var1[45] = "CONF:CURR:DC 0.1, DEF;:SAMP:COUN ";
char var2[45] = ":SAMP:SOUR TIM;:SAMP:TIM ";
_itoa(sample_number,samp_num,10);
for(int i = 0; i < sizeof(samp_num); i++)
if(samp_num[i] == '\0')
samp_num[i+1] = '\0';
samp_num[i] = ';';
break;
int k = 0;
for(int i = 0; i < sizeof(var1); i++)
if(var1[i] == '\0')
for(int j = i; j < (i + sizeof(samp_num)); j++)
var1[j] = samp_num[k];
k++;
break;
sprintf(samp_int, "%.2f;", sample_interval);
k = 0;
for(int i = 0; i < sizeof(var2); i++)
if(var2[i] == '\0')
for(int j = i; j < (i + sizeof(samp_int)); j++)
var2[j] = samp_int[k];
k++;
break;
table[i] = var1[i];
k = 0;
if(var1[i] == '\0')
for(int j = i; j < (i + sizeof(var2)); j++)
table[j] = var2[k];
k++;
break;
for(int i = 0; i < sizeof(table); i++)
if(table[i] == '\0')
for(int j = i; j < sizeof(table); j++)
table[j] = '\0';
break;
int retval_size = 800000; // Set this variable to the maximum size of the array.
char *retval = new char[retval_size];
long opc = 0;
ViSession defaultRM, vi;
ViStatus viStatus = 0;
viStatus=viOpenDefaultRM(&defaultRM);
viStatus=viOpen(defaultRM, DEVICE_ADDRESS, VI_NULL, VI_NULL, &vi);
if(viStatus)
return 666;
viSetAttribute (vi, VI_ATTR_WR_BUF_OPER_MODE, VI_FLUSH_ON_ACCESS);
viSetAttribute (vi, VI_ATTR_RD_BUF_OPER_MODE, VI_FLUSH_ON_ACCESS);
viSetAttribute(vi, VI_ATTR_TMO_VALUE, -1);
viPrintf(vi, "*CLS");
viPrintf(vi, "*WAI\n");
viPrintf(vi, table);
viQueryf(vi, "*OPC?\n", "%d", &opc);
viQueryf(vi, "READ?\n", "%#T", &retval_size, retval);
cout << retval << endl;
result = (float)calculate_average_result(retval)*1000;
viGpibControlREN(vi, VI_GPIB_REN_ADDRESS_GTL); // go to local
viClose(vi);
viClose(defaultRM);
delete[] retval;
return result;
double calculate_average_result(char retval[])
int arraysize = 15;
int j = 0;
int licznik_znakow = 0;
int licznik_kropka = 0;
int czy_kropka = 0;
int czyE = 0;
int EE = 0;
long long lolek = 0;
double result;
int retval_size = 500;
int result_counter = 0;
double sum = 0;
for(int i = 0; i < retval_size; i++)
if(retval[i] == ',')
result_counter++;
result_counter++;
char **tab = new char *[result_counter];
for ( int i = 0; i < result_counter; ++i )
tab[i] = new char[16];
for ( int j = 0; j < 16; ++j)
tab[i][j]= '\0';
int k = 0;
for(int i = 0; i < result_counter; i++)
for(int j = 0; j < 16; j++)
tab[i][j] = retval[k];
k++;
if(retval[k] == ',')
k++;
break;
double *res_table = new double[result_counter]();
for(int count = 0; count < result_counter; count++)
j = 0;
licznik_znakow = 0;
licznik_kropka = 0;
czy_kropka = 0;
czyE = 0;
EE = 0;
lolek = 0;
arraysize = 15;
int *myvector = new int[arraysize]();
for(int i = 0; i < arraysize; i++)
if(tab[count][i] == 69)
czyE = 1;
break;
if(tab[count][i] == 46)
czy_kropka = 1;
licznik_kropka = 0;
if(tab[count][i] > 47 && tab[count][i] < 58)
licznik_kropka = licznik_kropka + 1;
myvector[j] = tab[count][i] - '0';
j++;
else
licznik_znakow = licznik_znakow + 1;
if(czyE == 1)
for(int i = j + 2 + licznik_znakow; i < arraysize; i++)
EE = EE + (tab[count][i] - '0');
arraysize = j - 1;
lolek = lolek + (myvector[i]) * (pow(10.0, (arraysize-i)));
lolek = lolek + myvector[arraysize];
if(czy_kropka == 1)
result = (double)lolek / pow(10.0, licznik_kropka);
else
result = (double)lolek;
if(czyE == 1)
result = result / pow(10.0, EE);
delete [] myvector;
res_table[count] = result;
sum = sum + res_table[count];
delete [] res_table;
for ( int i(0); i < result_counter; ++i )
delete [] tab[i];
delete [] tab;
tab = NULL;
return sum/result_counter;
Edited by: white-star on Nov 5, 2015 1:52 AM
float result;
sample_number = 1;
char samp_num[10];
char samp_int[10];
char table[90];
samp_num[i] = ';';
break;
int k = 0;
if(var1[i] == '\0')
k++;
break;
k = 0;
if(var2[i] == '\0')
k++;
break;
table[i] = var1[i];
k = 0;
if(var1[i] == '\0')
table[j] = var2[k];
k++;
break;
table[j] = '\0';
break;
long opc = 0;
if(viStatus)
return 666;
viClose(vi);
viClose(defaultRM);
delete[] retval;
return result;
int arraysize = 15;
int j = 0;
int czy_kropka = 0;
int czyE = 0;
int EE = 0;
double result;
double sum = 0;
result_counter++;
result_counter++;
tab[i][j]= '\0';
int k = 0;
k++;
k++;
break;
j = 0;
licznik_znakow = 0;
licznik_kropka = 0;
czy_kropka = 0;
czyE = 0;
EE = 0;
lolek = 0;
arraysize = 15;
czyE = 1;
break;
czy_kropka = 1;
licznik_kropka = 0;
j++;
else
if(czyE == 1)
arraysize = j - 1;
if(czy_kropka == 1)
else
if(czyE == 1)
delete [] myvector;
delete [] tab[i];
delete [] tab;
tab = NULL;
http://helpdeskgeek.com/windows-xp-tips/prevent-windows-from-powering-off-usb-device/
It is also good to have newest Keysight IO Libraries installed. I think the topic can be closed.
