I need to create a sine frequency sweep "summed" with either the internaly generated Gausian noise or an external input from an external source. Can this be done with the 33509B single channel? Owners/operators manual states modulation is disabled when Freq. sweep is enabled. Is "SUM" considered a modulation type?
Thanks
Thanks
