Dear Sir,
I would like to know whether it is possible to access digital output (4 channels) of DSO9404A oscilloscope through Ethernet using LabVIEW. I tried with DSO9404A IVI drivers and example VIs are available in LabVIEW to control the scope, but it is throwing errors. Kindly let me know the procedure to automate the oscilloscope.
Thanks & Regards,
S Nagaraju,
+91 9989554142
Thanks & Regards,
S Nagaraju,
+91 9989554142
- What version of Scope SW?
- What version of LabView?
- Have you used LabView before?
- Have you done scope programming before?
- What are the error messages?
- Are you using IOLibs? If so, does it see the scope? Can you send commands and get results using it?
Al
Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
