I am trying to install BanchVue 2.7 on windows XP computer, and it look like it do not getting thru.
It first get error finding the directory where the Agilent Licence Menage should be. If you continue and choose arbitrary directory it will give message that the installation was not successful it will try to install some VB 2008 component and it will give again message that the installation is not successful.
After that it give couple other error messages.
There is no problem with windows 7 installation of version 2.7. I can also install the old version 1.1 of Banchvue with out any problem.
I also notice if I download the standalone version of Agilent Licence Menage (AgilentLicenseManager_4.6.19016.12135) it also will not install successfully on windows XP.
Any solution for the above issue?
Regards.
Regards.
BenchVue does currently work on XP, although support will be ending with our next release. It would be wise to consider retiring your XP machines at this point, because Microsoft is no longer supporting that OS. That said, installation problems are almost always a result of inadequate permissions. You must have administrator privileges to install BenchVue. You would also need a working LAN so that the licensing service and VC++ redistributables can be installed.
Brian
