Dear Team,
I have some questions on VEE 9.3. I can't read data from 34461,4263B and E4980AL when I setting trigger soure:External
Does anyone have any idea of how to do it?
Best Regard;
Best Regard;
you still need to instigate the measurements - typically the program puts the the instrument in a 'wait for trigger' state and then the trigger arrives
look for the measurement complete e.g. by polling the instrument or simply have a blocking wait for it to return
then fetch the data from the instrument
I'm sure it's obvious that in that sequence the hardware trigger signal needs to be applied to the instrument typically via a BNC Trigger In socket on the rear of the instrument.
HTH,
Mike Watts
