Hello!
Can you help me,please?
We have 33522b model generator.I create a signal in the benchlink waveform builder.A duration of the signal is constant.According to a test I have to slowly vary the signal frequency from zero to 0,5 Hz, but when I change the frequency by the generator, the pulse width was changed.Can I change the frequency without changing of the pulse width?
Thank you.
Thank you.
